configure vm-tracking vpp counters
configure vm-tracking vpp vpp_name counters [ingress-only | egress-only | both | none]
Description
Configures whether counters need to be installed for Virtual Machine MAC which receives this VPP mapping.
Syntax Description
ingress-only Only counts packets ingressing the switch whose source MAC address matches VM MAC.
egress-only Only counts packets egressing the switch whose source MAC address matches VM MAC.
both Counts packets ingressing and egressing the switch whose source MAC address matches VM MAC.
none No packets will be counted.
Default
N/A.
Usage Guidelines
Use this command to configure whether counters need to be installed for Virtual Lachine MAC which receives this VPP mapping.
Example output not yet available and will be provided in a future release.
This command was first available in ExtremeXOS 15.3.
Platform Availability
